Does anyone have ideas on what could cause a consistent engine cut at circa 5200 rpm. It isn't boost/load related as it happens whether I set the boost to 13 or 26 psi.
I am running 034efi on an Aby but can't find anything in the sensing system or software, the issue started ever since I had an overboost issue while trying a stronger Wg spring and blew the plastic end cap off the intercooler. I've now fit a brand new IC and it flies up to circa 5.2k rpm but then just cuts out suddenly.
