Hi,
I have a next problem. VEMS detect primary trigger in log file but secundary trigger no.
Actually i use camHall invert is OK and i measure with scope JP20 signal directly ( Secundary trigger VR ) and CamHall input in EC36-13.
By datasheet of LM1815 in MODE 5 put at 5V the output is active if measure peak-to-peak more that 200mV. Actually i think my problem in reference pin in 7A flywheel. I have peak-to-peak " only " 200mV.
Anyone confirme if the problem is it?
Many thanks.
Many thanks.
