I will get the file from the laptop tonight. Do you have any old config files for this ecu? Can you remember what settings the tooth reference needed due to no cam inverter? Cheers.
Ok here it is as supplied from vems. I may of messed with req fuel only at this point. I changed the file name to . txt from .vemsconfig to upload Thanks Des
Your right sorry, remember wrong. That was for crank sensor...
