Vems ign based idle cold start
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    Hello
    My car idle fine with ign based idle setup But when cold it wont idle for about a min or two
    I have to keep it alive with some throttle
    Is it my Cold start setup i need to make change in? And What change more or less fuel?
    I havent made Any changes in it since i started with ign based idle
    Cold start is set to -10 and aims at 1200 rpm
    Once the engine has been on for 30-60 sec the problem is gone
    Any one Got an idea?
  • morgenlatte
    • Jan 2013
    • 101
    • Country: Austria
    send a log or config file, i'll look over it
    1990 Audi 100 2.2 Turbo Quattro with VEMS, K24 2480, ported and milled 10v head
    • s2dk
      • Jul 2016
      • 507
      • Country: Denmark
      Cool Will Do it later when Im on my pc
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        the same problem over here
        when i do a cold start the engine barely keep running on low revs and after a minute or so it turns very well
        i dont think this can be solved because i dont use the idle control valve anymore,it's deleted
        i have played with the cold start adjustments in vems but no results
        TWINCHARGED power,zero lag
        AEM W/M injection
        • morgenlatte
          • Jan 2013
          • 101
          • Country: Austria
          unfortunately you need a bit more air at cold start.. maybe open your throttle a litte bit more and retard the timing when it gets warm to come down with the rpm at idle
          • s2dk
            • Jul 2016
            • 507
            • Country: Denmark
            Hmm Maybe less fuel with less air?
            I dont know yet But Yes Could open it a bit more and the foxit with timing so it runs fine when hot
            • s2dk
              • Jul 2016
              • 507
              • Country: Denmark
              Im running 10 or 11 deg timing in idle
              Higher the. It runs higher rpm Then it should be lower If i open TB more
              • morgenlatte
                • Jan 2013
                • 101
                • Country: Austria
                you need more fuel when the engine is cold, if you lower your fuel, it won't run better.. try to open the TB a litte bit and let fuel the same.. but send me a log or config anyway
                • s2dk
                  • Jul 2016
                  • 507
                  • Country: Denmark
                  Okay Will try that
                  But i Will need to change the timing If i open tb
                  • morgenlatte
                    • Jan 2013
                    • 101
                    • Country: Austria
                    yes, ofcourse you have to retard it
                      First, I would quickly try more after-start enrichment for the relevant temperature range When cold most of the fuel is not in a combustible state - condensed on the port walls etc.
                      • s2dk
                        • Jul 2016
                        • 507
                        • Country: Denmark
                        Will try that in a min or two
                        To see If it helps
                        It was around 12-15 c herr in the morbing
                        • s2dk
                          • Jul 2016
                          • 507
                          • Country: Denmark
                          Aftenstart did nothing to it sadly
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            Agree with error. I aim for a mixture of about 0.90 when cold, and only try to get it to 1.00 after engine reaches 50C in coolant.
                            Check afterstart enrichment and also disable lamda control for up. To 50C temp while adjusting your enrichment curve for the above lamda
                            • s2dk
                              • Jul 2016
                              • 507
                              • Country: Denmark
                              okay will try that. engine is not cold atm so have to wait . what about general timing?
