Hi searching through internet all day for some porsche calipers around my way (sorry bry) i came across some gt3 calipers. I am not sure if they are four pot or six pot yet. If they are four pot calipers would i be able to fit them under the 16'' avus wheel? Also what else would i need to fit these is it the same as the 996 rout i.e rs2 carries, rs2 brake lines etc. I have checked through all the threads regarding gt3 calipers and cant seem to find a definative answer. Thanks for your help
Gt3 calipers
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
This is a pair im interested in although i might be getting some monday which are not on ebay. I thought gt3 calipers came in 4 and 6 pot? Iwas lead to believe the earlier gt3 calipers ar 4 pot but the larger 6 pots were on the later gt3's. If i got these what is the minimum size wheel i would need and what carries would i need?3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
well i have arranged a deal with someone for these calipers. They are in mint condition faultless. if they are 4 pot will they get under my 16'' wheel. do the rs2 calipers go with them aswell.3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
as far as I know, the turbo / GT3 calipers's mounting bolt holes are spaced further apart than the standard 996 calipers.......150mm rather than 130mm..Originally posted by stevieyid. if they are 4 pot will they get under my 16'' wheel. do the rs2 calipers go with them aswell.
I believe this info came from a seller on e-bay I mailed a while ago - but don't quote me on that!Comment
What size wheels would i need for these? Also how much are they worth for the two front calipers in mint condition? Would i need custom carriers? If i dont get them would anyone be interested on here in getting them?3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
I maet for the gt3 calipers sorry. I have a deal with a guy for which i think is a good price i just need to no what size wheels i would need for them and what other parts i would need to fit them. What are gt3 calipers worth in mint condition?3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
what about these calipers from germany? Are these monoblocks or are they the other style 2 piece bolted together like the rs2 ones. Would these fit with the rs2 carriers and rs2 brake lines and a8 discs etc
http://cgi.ebay.de/ws/eBayISAPI.dll?...986113987&rd=13'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
Looking at my wheels, i would say you need bigger than 19" to get 390mm under there! i dont think there is that much room under my wheels!Originally posted by 4WheelDrifterFor 390mm discs you would need at least 19" wheels.
I know the 323 is a tight fit on 17's, so 19's gain an extra 50mm roughly, so thats around 370mm max, obviously as just a guessAnt
2011 Kawasaki Z1000
345mm disks would fit under my 17" wheels, leaving ~2mm of clearance between the calliper and wheel weights. There's loads of clearance with my 323mm disks. I guess it depends on the design of wheel. AFAIK the S65 AMG has 19" wheels.SSComment
