Disc Size
  • Albie S2
    • Oct 2004
    • 138
    • Country: South Africa
    Disc Size
    Hi
    Can any1 help i need the front disc sizes for 91 s2 3b 20v standard and what other audi used this disc 5 hole 112pcd
    thks chris
    need the zise in mm please
    www.cardomin.com/member/745893
  • porkkis
    • 1994
    276x25 and it's s2 specific in 5x112 bolt pattern.
    20v N/A coupe and 90 has the same size but 4x108.
    • Albie S2
      • Oct 2004
      • 138
      Thanks so there is no other audi using this disc.
      • Albie S2
        • Oct 2004
        • 138
        Sorry what i need is the the following sizes
        276mm is right
        then the thickness of the disc
        spiggot zise
        hight if u put it flat down from the bottom to the top.
        thanks chris
        • porkkis
          • 1994
          • Albie S2
            • Oct 2004
            • 138
            Thankyou Very Much
