Can anybody confirm the following:
03/04 A8 4.2q has 360X34mm discs.
W8 Passat has 330ishX32mm disc that have the radial pins.
Any further info on hat heights etc welcome.
Ta!
Ta!
I'm not guru, however - see for yourself
A8 2004 (note chasis number differences)
4E0615301A brake disc (ventilated) 360X34MM 5/112
F >> 4E-4-015 000*
4E0615301G brake disc (ventilated) 360X34MM 5/112
F 4E-4-015 001>>*4E-5-005 000*
4E0615301P brake disc (ventilated) 360X34MM 5/112
F 4E-5-005 001>>*
Passat 2004 has NO 330x32 disc, only brake disc (ventilated) 334X32 17"
3B7615301B brake disc (ventilated) left 1
3B7615302B brake disc (ventilated) right 1
Note, that passat discs seems to be made by quattro gmbh, and available only from VAG for more than 400e each.
Sau
