simple help. changing dust caps on bigreds.
  • RS2.pt
    • 155
    Hi all
    Since I want to play safe, I am asking this "simple" question...
    I am about to replace those little rubber dust caps on RS2 BigReds in rubber. Do I need to untight the bleeders??? (hope not) or the dust caps come off easly and can be inserted the new ones easly to?
    Anyone did this procedure before?
    I know yhis is not big issue but if I need to unbolt the bleeders, I wait when change the bake oil...
  • Martynf
    • 1885
    Hiya,
    they just pull off so you are ok.
    They are rubber so when fitting the new ones, they will stretch over the bleed nipple. You can just pull the old ones off ok.
    Martyn
    www.vagparts.com
    • RS2.pt
      • 155
      Originally posted by Martynf
      Hiya,
      thanx Martynf !
      go put those litle nipples on my shop basket ;-)
