brake pad options rs2, s2, porsche monoblocks
  • Tommy200rs
    • 285
    I collected some pad info of non dust carbon pads.
    If you know other good alternatives, please post here your comments.
    Kerr Friction FRONT pads in street compound as follows
    Monoblock Boxter @ $140.00
    Monoblock BoxterS / 996 @ $172.00
    The KFP pads are equivalent to the Ferodo pads listed (street compound):
    FCP 451H = KFP345 @ $104.00
    FCP 891H = KFP594 @ $164.00
    FCP 560H = KFP372 @ $160.00
    FCP 1348H= KFP592 @ $113.00 baby seat brembo
    Weston MotorSports USA
    888 558 0631 - office
    813 486 1531 - cell
    813 926 9713 - FAX
    other vendors and pad types:
    EBC offers pads too to Monoblock calipers:
    http://www.ebcbrakesdirect.com/?source=googleebc
    TEXTAR:
    - original and dusty
    - thanks for the link Porkkis !
  • RS2.pt
    • 155
    Hi
    I went on EBC site, and looked for RS2.
    On part list below the say:
    "Notes: EBC Technical recommends using Redstuff compound for this model of car."
    on picture notes they say RedStuff is for track days. so Green or Red?
    I praticlay dont use my rs2 on trackdays ... and doesnt RedStuf will "eat" more diskbrake?
    • dan_b
      • Sep 2003
      • 3670
      Redstuff is able to operate at a higher max temperature than Greenstuff but has a lower friction coefficient than Green; they recommend using only Redstuff on the S2 because they say you'll overheat the Greens due to the S2's high performance and high weight and low disc size, and the Greens higher friction (works the discs harder).
      In my experience, I found that Redstuff had poor initial pedal bite and feel - it's as if they actually need some heat in the pad in order for them to work fully.
      For a while I was running Redstuff at the front and Greenstuff at the rear and on track that was fine.
      Also in my experience, I think the Ferodo DS2500 pad is far superior to the EBC Red.
        Ferodo DS2500 pad although more expensive is brilliant on the Porsche calipers, my car stops on a dime.
