Occasional judder on the pedal..
  • Coxy
    • Jun 2005
    • 1090
    My other half noticed it happening last week and I did as well yesterday when driving her RS2. Only happens occasional (maybe once every 20 times) but when you push on the brake pedal for a second it feels like it's "biting back" if you know what I mean.
    Having only owned classics for the past 15 years, i can only presume that it maybe a small problem with the ABS?? It does not affect breaking and this happened to me twice, once was breaking from speed and the other was on approach to a T juntion which I was only doing about 10-15 mph...
    Can anyone point me right?
  • alg
    • Apr 2004
    • 1160
    Check for warped front discs
    Alastair
    RS2
    • mreinders
      • 72
      • Home: United Kingdom Current: Netherlands
      Also may be an idea to check the abs wheel speed sensors.
      I had this on my s4 recently, one wheel speed sensor intermittantly gave no signal below 10-15 kph and I got false abs cycling pulling up to junctions...
      Maarten
      010100110011001000101111010000010100001001011001
      011000100011010101010011001101000100000101110110
      • Fat Audi 80
        • 10547
        That type of thing should be thown up by pulling any fault codes you have.....
        The Perfectionist
        • pastures16
          • 2058
          sounds like a dirty or nailed sensor to me
          94 s2 avant
          aoc member 1116
          • s4_rider
            • Apr 2004
            • 44
            I had the same phenomena.
            It was the toothed wheel of the ABS that was broken.
            There is one for each wheel. It triggers the pulse signals.
            see photo:
            S4 Rider
            • Sidspud
              • 1223
              • Home: Scotland Current: United Nations
              Maarten
              I had the same on my Avant. It turned out the ABS sensor was OK, but the sensor ring (toothed wheel in the hub) was cracked. This is seemingly quite a common fault on VAG cars.
              Unfortunately for me I never got mine fixed in time and skidded into the back of another car resulting in a write off!
              ex '93 Avant owner
              • GeorgeS2UK
                • Oct 2004
                • 225
                • Home: England
                [QUOTE=Coxy]My other half noticed it happening last week and I did as well yesterday when driving her RS2. Only happens occasional (maybe once every 20 times) but when you push on the brake pedal for a second it feels like it's "biting back" if you know what I mean.QUOTE]
                I had the feeling of pedal judder and it turned out to be the brake bomb
                May not be in your case but I ended up replacing the bomb and all symptoms went.
                Good luck
                George
                91 S2 3B in Pearl, Miltek, De-Cat pipes, Short Shifter, 996 Monoblocks + 323 A8 Discs, Whiteline R-ARB:MRC Generic 3B Chips
                • pastures16
                  • 2058
                  easy way to put this to the test is unplug you abs relays that will tell you if its the bomb or not
                  94 s2 avant
                  aoc member 1116
                  • Chris5044
                    • Feb 2005
                    • 1663
                    my brakes!!!!!!!!!!!!!
                    well my car swerves all over the shot and brakes are **** when i brake ... i own a s2 with standard brakes..... ok the standards are crap... my pedal feels like no pressure behind it and theres lots of travel b4 any resulting braking what could this be pls?????????
                    • BRY
                      • 3755
                      You wanted red calipers and not black ones.
                      Do you want black ones fitting this weekend?
                      I can't let a forum member drive round on sh@t brakes, can I?
                      • Chris5044
                        • Feb 2005
                        • 1663
                        cheers m8...... after reds ... need 2 first A: buy alloy wheels 18" then i can buy a set off u m8 ..... i am a student atm........... so im sorry havent been as quick as most people are on this forum.... its really pissing me off...... need brakes!!!!!!!!!!!!!!!!!!!!!
                        will buzz u asap when i get money and wheels... (got student loan coming soon mmmm)
