Porsche 996 caliper bolt on.
  • AAH!
    • 497
    • Home: United Kingdom Current: Bhutan
    Here is a list of all the RS2/porsche caliper bits:
    formally RS2 +
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      The 993TT callipers aren't exactly direct bolt on. IIRC the 993 has leading callipers, so the fluid crossover pipes and bleed screws need swapping.
      SS
      • Chris5044
        • Feb 2005
        • 1663
        i heard that if u buy seat cupra r brackets ..... all u need to do is machine one of the sides down a few mm ..... they bolt on 996 calipers straight on ...... sorted and they r cheap too
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          I not sure if we're helping Ross here. I don't think Seat carriers will do it somehow.
          SS
          • Alistair C
            • 693
            #20
            nope the problem is with the caliper mounting bolt spacing - something the Seat brackets would do nothing to help.
            As said, these are 996 turbo or early GT3 calipers and will need custom brackets made to suit the disks you choose.
            A8 disks are also not going to be ideal as they're so much thinner than the intended disks for those calipers. Problem arises when you'd have worn pads and disks, everything'd be beyond its designed usage parameters. I'd suggest going something larger again perhaps custom bells with AP disks........
            Very nice kit - just not a particularly cheap upgrade route (like the std 996 monoblocs).
            • BRY
              • 3755
              #21
              You know where there are several pairs of 996 front calipers in BLACK
              I can take the GT3s off you aswell, if that helps.
              You need big brakes up front to have Porsche rears :mischeif:
              • ross25480
                • Jun 2005
                • 62
                Am off on holiday for a few days. Cheers for all your help so far. Looking forward to catching up on it when I get back.
