Hi Guys and Dolls
My S2 has developed an annoying alarm. Every time I go over a speed hump or enter or exit a drive way, this sign (!) in RED and a BEEP comes up on the dash check system.
I have pumped the brake pedal 50 times b4 it gets hard, so hopefully the Bomb should be fine. I have changed the float in the power steering fluid container, made sure its full, I have checked for leaks, I just cant find anything wrong
What causes this alarm and what do you suggest I do to try and fault find it.
