Any good Bry?
tiny wee pistons on the 4 pots - they're rears. You probably could get them to fit & work - but I don't think anyone knows what effect using calipers with pistons this small would have on the brake bias.
The 6 pots - well, no-one on here had used cayenne calipers before - for fear they were too big & had lug mounts rather than a radial mount. But it has been done (see here and the results look good on the S2. Definately a custom bracket job and possibly custom disks too!
HTH
Just watch the prices jump in 5 days! - I reckon £380 for the 6 pots and £240 for the 4 pots -
its only the colour that set them apart from the ones on cayenne turbo.
the original disc for the 4 pot is 330mm x 28mm, and 350mm x 32mm for the 6 pot.
the 6 pot is big, but they are lighter than RS2 front calipers.96 RS2
94 urS4
02 ALLROADComment
Straight from the man who has them!Originally posted by ridgercerits only the colour that set them apart from the ones on cayenne turbo.
I don't know as I have always thought them to be too big, however, you can't argue with facts and the facts are that they are designed to stop a heavy cayenne and they are lighter than standard RS2 calipers.
I don't have brackets to make these fit!Kingdoms are run by Kings, Dictatorships are run by Dictators.
England must be a Country. :mischeif:Comment
