Rear caliper sticking
This is a sticky topic.
  • mcandmar
    • Apr 2004
    • 5118
    Is it possible to dismantle the handbrake mechanism on these callipers, both of mine have now seized up to the point they only move with a large hammer
    And is anybody using the stronger ford return springs? ..i know sounds wrong
    Thanks,
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    I think they can only be rebuilt by Girling brake reco specialists. To be honest they aren't that expensive... Here's a trick, take them in and say your car is an S6 or S8 - you know with the 280mm vented rear discs. They'll supply reco'd calipers for that application, then you just need carriers and discs to complete a decent rear brake setup. Ahhh but you have the 20VCQ which might give you pain unless you are changing to 5x112 hubs. ****
    Paul
    • volcano rs
      • Jun 2005
      • 2265
      yes it is possible ,the hand brake mechanism siezes up you can actually free it with lots of wd 40 time and patience are they standard s2 calipers ?use pliers to move them side to side and keep spraying wd 40 it will free itself eventually .
      • mcandmar
        • Apr 2004
        • 5118
        **** is right, i have the same problem with doing a big brake upgrade on the front. Might have to give in someday and buy new wheels to go 5 stud.
        I was hoping to dismantle them to clean everything up and re grease. I'll give the WD40 a try and see if i get any success,
        Thanks,
        Mark.
        • PeterS
          • 423
          I rebuilt a rear caliper last week, took a bunch of pictures, which I will post later. The disconcerting thing was that the caliper only appeared to be a few years old. The caliper ebrake mechanism had a new seal, but little or no grease...hence the failure.. It took me about an hour to rebuild the caliper, and a second set of hands to compress the caliper spring cage. In the meantime, here's some info on a stop gap measure: http://www.20v.org/brakprob.htm#caliper
          Lucas rebuild instructions here: http://www.20v.org/brakere.htm
          BTW, the caliper e brake mechanism fails due to moisture working its way through the seal into the caliper body and corroding the ebrake mechanism - rebuilding entails replacing the seal, polishing the ebrake caliper piston, and ensuring the use of sufficient quantity of high temp, waterproof caliper grease....putting a stiffer spring won't prevent the corrosion :-)
          Peter S
          1990 ErsatzS2 - track toy
          1991 Coupe Quattro
          1991 Coupe Quattro
          1995 S6 Sedan
          1995 S6 Wagon
          • mcandmar
            • Apr 2004
            • 5118
            Perfect thanks
            • PeterS
              • 423
              rear caliper internals
              2nd try on the internals
              Peter S
              1991 Coupe Quattro
              1991 Coupe Quattro
              1995 S6 Sedan
              1995 S6 Wagon
              • Nuvo
                • Nov 2003
                • 3825
                Peter, the above JPEG looks to be heavily compressed? The image is very blocky.
                • PeterS
                  • 423
                  more on the ebrake mechanism
                  Peter S
                  1991 Coupe Quattro
                  1991 Coupe Quattro
                  1995 S6 Sedan
                  1995 S6 Wagon
                  • PeterS
                    • 423
                    Ebrake mechanism on the caliper...
                    look at the rust in the cylinder bore...
                    Peter S
                    1991 Coupe Quattro
                    1991 Coupe Quattro
                    1995 S6 Sedan
                    1995 S6 Wagon
                      Gawd I love this forum... logged on tonight in search of good info on stripping a rear caliper - as my left side has seized handbrake mechanism... hydraulic piston action is fine so hopefully I can loosen up the handbrake.
                      Making it a sticky thread too.
                      • S2Phil
                        • Apr 2010
                        • 54
                        • Home: England Current: Wales
                        I remember having the same problem a few years back, called Audi for a price on a new caliper and they said there was a service exchange item avaliable. Hmmmm I thought, if they are offering service exchange then there must be a way to pull them appart, so after about 10 minutes of getting the caliper on the bench it was in bits, and hour later seals out all nice and clean and put back together.
                        Audi wanted £140, glad I had a look.
                        • AndyP
                          • 6049
                          I'm sure Rob ( GT500 ) has mentioned before that he drills and taps his to put a grease nipple in them. Maybe he could post up some pics?
                          • mcandmar
                            • Apr 2004
                            • 5118
                            This thread goes back a while
                            I have had to do this many times over the years. Trick is to find the right sized socket so you can mount the calliper in a vice while compressing the spring inside. Also wear some eye protection when removing the c-clip, it has a tendency to spray brake fluid at you when it pops out. Getting the c-clip back in will take a bit of patience, not a difficult job just a bit fiddly.
                              I have rebuilt a set of rear calipers and my advice is don't bother - massive PITA as the spring mechanism is really (really!) hard to reset without the right specialist tools to compress the spring. I'd never bother to attempt it again, just buy some recon exchange ones IMHO
                              However, I have the weird internal long nose 90deg circlip pliers you'll need if you decide attempt it, drop me a PM if you need Paul
