RS2 Handbrake solution maybe ???
Tags: None
had seen this a while back and i didnt email them.I figured that i would have to go through building mounting brackets and welding stuff on the rear wheel mounts to make them work,and was not up to the task.
i ended up replacing most parts on the original handbrake,renewing the e-brakes with new shoes,i found the audi workshop manual on how to fix the handbrake and just 2 days ago went to have it strenghten one final time.
now it onle goes 3 clicks tops.With 2 clicks it holds the car mostly everywhere,and with 3 clicks on more than decent slopes,which is very acceptable,if not perfect cause if you actually use the gear as well it is a perfect stop!
I just hope it holds a good deal like this!thats all!
on the rszwei forum they told me that if you use slightly the handbrake on the highway while doing 80kms for example,lifting it about 1 click(or 2 if you have it modified to stop the car on 4 clicks)and do about 100 meters(using for a few secs),it cleans the shoes out of dirt and mud and makes it working again! -
Yea,
Main problem is our brakes pull from the center of the car not from the front or rear.
Greg W.They can have my car when they pry my cold dead fingers from the steering wheel.Comment
