gentleman
My avant has started with a tendancy for the abs light to come on after about 1/2 a mile ..
Thought it might be abs wheel sensors so took em out and cleaned them still the same checked the connection an abs computer and is fine pump charges when ignition is on and light automatically goes out on computer check any ideas or is it bry and the vagcom as the next step...
only standard brakes as well i wouldnt mind if it was a trick setup that had a problem..lmao it dont stop very well with abs working never mind without ..
