RS2 Brake lines
  • martinjs
    • 3205
    The thread is M10x1mm i beleive, and i think for the front pipe your on about you need female fittings both ends, double check that though.
    • Billman
      • 4129
      I need for starters this one:
      I think the RS2 has 2 lines at the front and 4 at the back!
      Go Holset or Go RS4
      • martinjs
        • 3205
        Yeah thats it, the lengths are on Etka, i had mine made up, and just added 10mm or so to the lengths, coupe just has 2 at the rear though.
        • Billman
          • 4129
          i know the length! The problem are the fittings!
          Go Holset or Go RS4
          • Jas11n
            • 5067
            The fittings are as Martin says, M10x1mm.
            A female M10 into the line at the strut tower, and a male M10 into the caliper.
            Female M10;
            Male M10
            2001 Avus Silver B5 RS4.
            1995 S2 Coupe - sold (sniff)
            • Billman
              • 4129
              #21
              That what i want is not for the exsactly for the calipers but more in th eway up! Look at the link i posted!
              You mean in the caliper direction dont you??
              Go Holset or Go RS4
              • Jas11n
                • 5067
                As I said above, A female M10x1mm into the hardline from the strut tower!
                • Billman
                  • 4129
                  #23
                  Thanks Jas! Waiting for an answer of someone and if it's not going to work then i am going this route!
                  Thans alot, all of you!
                  Go Holset or Go RS4
                  • GlynRS2
                    • Dec 2003
                    • 307
                    #24
                    VAG Parts keep the Goodridge hoses in stock. Martyn commissioned Goodridge to make these, supplying them with new OE RS2 hoses to ensure an exact fit. The Goodridge hoses are all stainless and have been TUV approved. I have these and they are a top quality product.
                    Glyn
                    Ex-Polar Silver RS2
                    Sprint Blue RS4 - new toy :mischeif:
                    • Billman
                      • 4129
                      #25
                      @Glyn
                      How much did you paid for them???
                      @Jas
                      Is there any Inner Imbus or something like that on the hoses?
                      Go Holset or Go RS4
                      • Jas11n
                        • 5067
                        Originally posted by Billman
                        @Jas
                        Don't quiet understand what you mean
                        The brakeline I used is a teflon inner pipe, with a stainless steel overbraid and then a clear plastic sleeve covering that.
                        Hope this is what you meant.
                        Jas
                        • Billman
                          • 4129
                          #27
                          not exsactly but its ok! I have have the info that i wanted!
                          Thanks for your help!
                          Go Holset or Go RS4
