Whilst driving home from work my front brakes started binding on ,so badly that you could smell burning and it took a bottle of water to cool them enough to drive two roads to get home.
I have since changed the bomb for one I bought from ebay and replaced the inner and outer front brake flexibles because they seemed to have a slight restriction when blowing through them, i stripped the calippers and they seemed fine no corrosion or sticking when i tried them with the seals out.
All four wheels lock and free off when on stands in the garage but out on the road the fronts over heat in less than a mile,has anyone had a similar experience or have any ideas what to check next.
Thanks... acp
Thanks... acp
