Been having this discussing about upgrading brakes and one of the points that were raised were the actual physics of it all
Understanding the fact that upgrades helped in a sense with the fact of Four Pot Calipers, bigger surface area for friction and decreasing speed and heat displacement ,but a few questions came up 'that could the servo/master cylinder handle the extra load from the bigger piston size and maybe cause uneven braking .........and that you would not get the full braking capicity that you should get as Porshe have upgraded Master Cylinders for Turbo Models?
Your Thoughts
Your Thoughts
