Jag Calipers
  • Azman
    • Sep 2005
    • 3205
    Jag Calipers
    Hi guys.
    These any good?
    http://cgi.ebay.co.uk/JAGUAR-XKR-XJR...QQcmdZViewItem
    Take a mightily thick disc!!!
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • Azman
    • Sep 2005
    • 3205
    Or these
    http://cgi.ebay.co.uk/Brand-New-MGF-...QQcmdZViewItem
    Dark Grey Avant
    RS2 FARB
    • Corey
      Banned
      • Sep 2003
      • 2793
      The front Jaguar items are interesting as they are mono's but may be difficult to fit due to the limitations of them being lug mounts rather than radial, disc offset, diameter, pitch of the mounting bolts etc...
      Or they may bolt straight on, stranger things have happened???
      Corey
      01636 822288
      • Azman
        • Sep 2005
        • 3205
        The fronts look to have a bit of a pitch to them though
        Dark Grey Avant
        RS2 FARB
        • Azman
          • Sep 2005
          • 3205
          Rotorboy in action again?
          http://cgi.ebay.co.uk/AUDI-QUATTRO-T...QQcmdZViewItem
          Dark Grey Avant
          RS2 FARB
          • MidnightBlueS2
            • Jul 2005
            • 1653
            • Home: United States Current: Belgium
            I can hear BRY shuffling in the background too...
            Midnight Blue S2 - SOLD - 1993 S2 Avant
            • nbvtec
              • Mar 2006
              • 28
              Originally posted by Azman
              Care to expand please. I was looking at that set but if there's issues, obviously they will left alone.
              • kwlw
                • Sep 2004
                • 1025
                • Country: Lithuania
                Hi guys.
                These any good?
                Problem is bracket and wheel clearance. Also it may require to make custom brake discs from alloy hats and brake rings just to deal with hub offset. Everything can be done, however you will need some 18" wheels, custom brackets, custom discs which will cost you a fortune. So the calipers themself can be only option if they are mega cheap . If not - forget them and go with normal route, I mean 996 mono + A8 disc + rs2 carrier. Reinventing the bike is my scope
                Sau
                • Azman
                  • Sep 2005
                  • 3205
                  Chheers
                  Dark Grey Avant
                  RS2 FARB
                  • martinjs
                    • 3205
                    But do you want to fit parts on your car that say Jaguar or even worse MG on them lol
                    • Azman
                      • Sep 2005
                      • 3205
                      The Jag can be sprayed off!!!!
                      Dark Grey Avant
                      RS2 FARB
