I just change the bomb on my car for a brand new one.
So made the test after fiting it and just 3 brake pomp and the pedal get's rock hard.
Tried also with engine on and after 5 braking pomp pedal is rock hard and almost no travel.
I cannot do all the test from sjm as I never got any warning light's coming on the dashboard.
So do you think I should change now the pump or would it be the hydrolique servo (booster amplifier)
the pedal feeling is most of the time very hard need a lot leg strenght yo stop the car.
Pump make lot of noise when hot.
If I keep on pressing the brake pedal it go slowely down and down untill bottom after a minute or so
