Another 996 Disc Option??
  • S2Roo
    • 191
    I'm looking to get a brake disc to finish off my 996 conversion, and I wanted a cross drilled disc. The only one I can find that is just cross drilled is a brembo disc at £360 a pair. Does anyone knoe where I can get a Zimmerman cross drilled disc from???
    Secondly I was going to use the 323mm x 30mm A8 option, but I've hear this is very tight on clearance. I didn't want to use the 314mm A8 disc, as I don't like the thought of the pad overlapping the disc.
    Has anyone considered using the Allroad or the A6 disc that is 321mm by 30mm. It has the same PD, is this a viable option. I've attached a family album pic. It seems to me to be the closest size to the original Porsche disc????
  • Jon441cc
    • Dec 2005
    • 2061
    These cross drilled discs 323mm
    nordmannbremsen ist der größte deutsche Sportbremsenhändler. Umfanreiches Sortiment von Sportbremsscheiben, Sportbremsbelägen, Bremsscheiben und Bremsenzubehör
    • martinjs
      • 3205
      I got mine from Black Diamond (323 x 30) x-drilled and grooved, but i wouldn't bother with x-drilled, just get grooved.
      • Corey
        Banned
        • Sep 2003
        • 2793
        The only crossdrilled disc to use is one that has the holes cast in (ala Porsche) anything else that has been "drilled" is a waste of time as it can lead to stress fractures around the holes and can lead to accelerated warpping.
        Corey
        01636 822288
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          Agreed, the wisdom around most parts (including this forum) would be to avoid drilled.
          As for the 314x30 discs sitting inside the pad, I am running 314s and my pads sit 1 or 2mm inside the disc edge Although I am using machined SEAT carriers so they have been machined to fit this disc
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            Yes. Two of my friends have tried Zimmerman drilled disks. Both sets cracked in no time.
            SS
            • Crawford_S2
              • 1555
              Yeap Zimmerman drilled discs blow, mine are goosed and am still on first set of pads. Wouldn't buy them again. Worst bit is the rust grows like little cauliflower out of the holes and wears the pads really funny so the disc surface is really grooved in no time. IMHO totally pointless
              Ragusa Coupe gone!
                They don't blow... They suck !
                Think y'all will find that grooves are the way forward.
                I'll check the family album about that Allroad suggestion. Seems kind of surprising - I thought the hat height was all wrong on those. Luckily I have an Allroad here I can check with huh
                Paul
                • Crawford_S2
                  • 1555
                  Paul
                  Blow, Suck, there is only one situation i can think of when this is a desirable thing And its not anything to do with brakes
                  Ragusa Coupe gone!
                  • Keeper of The Kitten
                    • Dec 2003
                    • 2317
                    Even though their standard kit included drilled discs, AP Racing recommended grooved to me when I was enquiring about brakes some time ago.
                    I think the picture of cracking above is the most graphic demonstration I've seen as to why drilling is a bad idea.
                    Go grooved!!! That's what I am doing.
                    __MDC__
                    Martin Cutting
                    • Bibby
                      • Aug 2004
                      • 1043
                      You can get Tarox G88 discs in 323 x 30 x 59.5 for the A8, pretty sure they fit the S2 with 996 calipers.
                      Not cheap at £200 a pair but they're good discs in my experience.
                      acidtrax
                        Agree with Corey (and others), Zimmerman discs aren't very good. Mine were knackered when I removed them, also for a Porsche conversion.
                        BRY sourced some grooved discs for my conversion (314mm) and they seem very good. Not sure of prices so contact him separately.
                        Pad overlap can be cured by machining the carriers.
                        • BRY
                          • 3755
                          Also available in 323mm
                          • WabTheKing
                            • May 2004
                            • 2567
                            ive found if you counter sink the drilled holes they are not as prone to cracking,
                            i drilled my 304x28 brembo discs and counter sunk them - no cracks and they have been on bout 10k
                              • Dec 2003
                              • 2317
                              But then the sharp edge that helps prevent pad glazing is lost?
                              __MDC__
                              Martin Cutting
