Looking at the calipers from a S60R or V70R, they sure are tasty. Now, they are axial mount which causes a bit of problems. Has anyone seen these things mounted on a Audi? I've seen them mounted om a BMW E30 but nothing else. Can anyone shed some light here?
S60R V70R calipers on S2
Originally posted by CoreyI'm with Ant on this too, why try reinvent the wheel? Or are you just trying to be different?
2Others:
However not many "cost savers" take in account performance . Not everything with 4 pots is panacea. Brake balance, caliper flexibility, disc availability, pads price and availability, carrier machining costs and durability must be taken into account. It's not unusal, that finally it becomes more expensive than "proper" set of monoblocks, rs2 carriers and A8 disc. If I had S2 - honestly I won't bother with custom setup. It's not worth the effort, unless you (or your bro) are running machine shop and scrapyard at the same time .
Sau
P.S. I have three custom brake setup designs on the way - reinventing the wheel inc. . However all of them are for TYP85 ONLY!200 20vt 88' 3b, human carrier
Mine are axially mounted and i have no problems, they are Bremsport 4000 series.Attached FilesEverything should be made as simple as possible, but not simpler.--:Albert Einstein
