opinions on these rear calipers?
  • Chris5044
    • Feb 2005
    • 1663
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MakeTrack=true
    sounds good ... brand new.. what u think?
    also a possibilty :
    http://cgi.ebay.co.uk/AUDI-COUPE-CAB...QQcmdZViewItem
    was used but cheap...
    anyone got any for sale?
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Have you noticed, that first item is stated "FWD only!" ?
    Sau
    • Chris5044
      • Feb 2005
      • 1663
      ok yep ... if they have calipers that also fit mine what do u think of these? as good as the original? better?
      someone here should know somig about aftermarket calipers?
      • Chris5044
        • Feb 2005
        • 1663
        anyone?
        • dan_b
          • Sep 2003
          • 3670
          Upgrading the rears is not straightforward if that's what you meant?
          I'm afraid I don't know if there are mechanical differences between the quattro and non-quattro rear calipers - I understand the discs are different though so possibly they're not the same.
          You could try finding a place called Fourringspares, they do good re-con stuff, I bought both my rear calipers from them when mine both finally seized up.
          • Graham
            • 1622
            Lawson car sales £60 odd quid each
            • Chris5044
              • Feb 2005
              • 1663
              thx guys ... ive tried these .. a bit too far to travel tho..... ill either get new from gsf or try to recon it myself... thx alot for replies
              • Stick Insect
                • Dec 2003
                • 2338
                Hi Chris, try this chap,
                He's a friend and can rebuild the master cylinders by lining them with stainless steel tubing.
                David
