Brakes and ticking noises....
  • SR71
    • Apr 2004
    • 330
    I've had my Porsche Boxster S conversion up front for a while...
    Recently I've developed, after heavy braking, a ticking noise from the brakes....
    I can make it go away by re-applying the brakes.
    The frequency of the ticking increases as I accelerate.
    After some time, the ticking noise will go away by itself.
    If I shut down the car and leave for a while, then go out again, the ticking noise vanishes until the next heavy application of the brakes.
    Clues?
    Anyone had a similar experience?
    Cheers.
    00 Audi B5 S4 MRC550
    08 RRS TDV6 HSE
    03 Kawasaki B2 ZX12R 1287cc
  • Corey
    Banned
    • Sep 2003
    • 2793
    Have you removed the dust shields?
    or have you fitted the pad dampers inbetween the pads and pistons?
    are you certain the disc is sat square in bewteen the pad retaining pins?
    Corey
    01636 822288
    • T2Andy
      • 1903
      mine does the same its just the disk expanding and catching the metal plate ,the ticking goes away as the disk cools ,
