996 Monoblocks fitted
  • Paulgo
    • Jan 2005
    • 498
    Well with a big thank u to Jas I finally have my 996 monblocks on the S2!! As per usual I just sort of watched and had little more arduous to do than pass the odd tool
    All went very smoothly - other than the fact that the Porsche dealer had supplied the wrong fitting kit as the bar/pin that holds the pads had it's circlip hole in the wrong place, the hole for the circlip was the wrong side of the pads (think I got a set for the rears) But a little bit of skilled drilling from Mr Armitage sorted that problem Im pleased to say. I can recommend the purchase of a brake spanner for this job, and a bloody big braker bar to hand!!
    some pics of the install!
    the old...
    Brackets on
    Some adjustments to the caliper pins
    Just about there!
    You beauties!
    All done and looking mighty fine!
    Certainly not the cheapest of upgrades but one I thought well worth investing in to offset that particular and well noted deficiency in the S2 - namely stopping power. We used the well tested combination of Seat brackets which needed to be machined in a little (more good work from Jas) and standard A8 Zimmerman 314 x 30mm vented discs. Textar pads, fitting kit and shims from Porsche, RS2 bolts and custom made stainless brake lines from Autopipe in Gateshead.
    And the results..... simply and utterly amazin!!! The merest touch on the brake pedal and the brakes bite hungrilly - grind the pedal to the floor and you are stopping with incredible shoulder bruising efficiency!! The confidence I now have with these brakes is just amazin - the car stops as it should upon command which allows you to really release the potential of the S2. I am in awe - and one well happy bunny!!
    cheers
    Paul
    Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
    Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
  • dan_b
    • Sep 2003
    • 3670
    Good to hear yet another S2 gets proper brakes - enjoy!
    • kriswithak
      • May 2005
      • 196
      • Home: England
      I have to do this. Soon.
      http://forum.funk-hq.com | http://www.no-rice.com
      twolitreturbooctaviavrs - '07 Skoda Octavia vRS - E.R.V.
      It might not be a 5 pot or an S2... but at least I have a 20v Turbo in my life again.
      • Fat Audi 80
        • 10547
        I have to do this too.
        A blast with Ross yesterday across the A43 from the M1 to M40 with half a dozen 120mph stops highlighted how bad the standard brakes are....
        The Perfectionist
        • Corey
          Banned
          • Sep 2003
          • 2793
          Welcome to the world of proper performance brakes.
          Corey
          01636 822288
          • dan_b
            • Sep 2003
            • 3670
            Get Ferodo DS2500 pads and it's even better
            The stock brakes are just horrible, especially if you've got a re-map. Definitely in my opinion you've got a faster car if you improve the braking first vs. getting the engine power up as you can brake harder, later, longer and without fade.
            • Fat Audi 80
              • 10547
              Don't I know it!
              tip-toeing around once the brakes have started to fade....
              The Perfectionist
              • Paulgo
                • Jan 2005
                • 498
                I'll agree with that!! - the whole car suddenly seems faster, meaner and complete now!! - and I can use all the power that even an unmodified 3b has to offer with confidence! Prolly be next weekend when I can really give the brakes a good try out on the way to the Lakes over Hartside. Cant wait!!
                cheers
                Paul
                • pastures16
                  • 2058
                  Paul
                  nice one paul whos the boldy
                  94 s2 avant
                  aoc member 1116
                    Looks like Corey?
                    • GirlRacer
                      • 747
                      Looking nice Paul
                      but sorry to say i need to borrow your mechanic next week..... BBQ ???
                      • Corey
                        Banned
                        • Sep 2003
                        • 2793
                        Originally posted by Jamo
                        Looks like Corey?
                        Nah not me,my tatoos are a lot bigger, although he does use the same shampoo as me though
                        Corey
                        01636 822288
                        • Corey
                          Banned
                          • Sep 2003
                          • 2793
                          did someone say food???
                          Corey
                          01636 822288
                          • s2driveruk
                            • 12696
                            looking good but why did u go with the 314x30mm disc was it to get inside the 16 rim?
                            Enjoy the archors
                            P.S. those brembo discs smell lush when u bed them in, like burning candles
                            1992 3b S2 Coupe
                            • BRY
                              • 3755
                              16" wheels = 314mm discs with clearance
                              Glad you like them Paul
