Pads question
  • s2driveruk
    • 12696
    Pads question
    Hi,
    Need to change my pads and discs and wondering what to go for. On the basis of wear i am happy to get another set of zimmerman cross drilled jobbies from G&S.
    Pad wise - greenstuff, redstuff, pagid RS 4-2-1black (med friction sport compund) or RS-4-2 Blue (race compound)
    Any views or BTDT on the above welcome.
    Cheers,
    David
    1992 3b S2 Coupe
  • Pisobiker
    • 1175
    Before upgrading to RS2 front disks and calipers, I used to have Pagid blue pads. In comparison with original ones bite was excellent (initial braking power doesn't seem dissimilar to RS2 front system). Only problem is fading with original disks (dunno with zimmermans). After few "aggressive" brakinigs disks become red hot and braking distances started raise dramatically :eek2: !!!
    Marco
    • S2 Ant
      • 3682
      I use the zimmerman X-drilled and vented discs and Pagid Fast road pads, they seem good to me, havent suffered from any significant brake fade...... yet.
      Altho to be honest, if upgrading power, a brake upgrade should always be considered cos its all well and good going faster but at some point or another your gonna need to stop just as quick!!!
      Ant
      2011 Kawasaki Z1000
      • Mark Halligan
        • 2001
        David,
        I'm using EBC reds on the front and greens on the back,and although the reds do need a little warming (one or two pedal depressions does it), I am well happy with them.
        My brakes are'nt standard though, 322mm front and 280mm rear but I doubt that matters with regards to overall impressions on pad performance.
        Mark.
        Mark - Modded
        • Mikes2
          • 1704
          Normally race compounds are not suitable for road use as they don't warm up sufficiently. I personally find EBC Greenstuff overrated - they cracked up badly when pushed. Ideally a pad with a central groove is best to aid cooling if using the G60 calipers.
          Mike
          http://www.s2-audi.co.uk
          • s2driveruk
            • 12696
            Grooves...
            Mike - i guess that can be achieved with any pad and a dremel right. Groove is dead centre so its in between both pistons i'd guess?
            Cheers,
            David
            1992 3b S2 Coupe
            • Alistair C
              • 693
              never had a problem with greenstuff. Previous owner got through a set in just over a year so can't have been light footed. Stop the car pretty well but I've not actually tried anything else on the S2 yet!
              subaru owners hate them. just look on scoobynet.co.uk.
              • Mikes2
                • 1704
                The pad normally arrives with the groove but if you want to add a DIY one to pads which don't, that is the best place between the pistons
                Mike
                • s2driveruk
                  • 12696
                  After a discussion with Demon Tweeks I decided to go with Ferodo DS2500 which are standard pads in AP racing kits. Apparently much better from cold, better feel, pretty much zero fade and kind to discs.
                  £117.50 with vat and carriage - expensive but much cheaper than a caliper and disc upgreade which i can't do at the moment.
                  Lets see how they perform, will keep you posted.
                  Cheers,
                  David
                  1992 3b S2 Coupe
                  • Doug_RS2
                    • 3847
                    David,
                    I use the DS2500 on my APs - they are only £80 for mine from Graham Goode Racing. I have to say they are a lot better than the Mintex M1144 I had on - AP told me to take them off ASAP!
                    • s2driveruk
                      • 12696
                      Damn......£80 would have been mucho better, do u have a contact number for these guys.
                      I guess that your pad price might be cheaper as they are for AP kits as opposed to the G60 caliper i have.
                      Cheers,
                      David
                      1992 3b S2 Coupe
                      • Doug_RS2
                        • 3847
                        Graham Goode Racing Leicester - Tuning Specialist in Fiesta ST - Focus ST & RS - Ford Cosworth & Subaru Parts - GoPro | Innovate | Milltek | Powerflex | Cherry Bomb | Worldwide Shipping
                        Tel: +44 (0)116 2440080
                        I think the pads are more of a generic pad - that's why it's easy to pick the wrong pad(Mintex) for the car.
                        HTH
                        • s2driveruk
                          • 12696
                          Cheers Doug!
                          1992 3b S2 Coupe
