Brake Bleeding
  • mcandmar
    • Apr 2004
    • 5118
    Brake Bleeding
    Can anybody tell me which order to bleed the system? I think i killed a set of pads and fluid last night
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • Audilard
    • Oct 2003
    • 87
    Right rear, left rear, right front, left front.
    Darin
    1989 Audi 80tq
      • dan_b
        • Sep 2003
        • 3670
        If you're doing it by yourself, I'd recommend getting the Gunsons Ezibleed from Halfrauds, it makes the fluid change a doddle to do. It uses the pressure of your spare tyre to push fluid through.
        • mcandmar
          • Apr 2004
          • 5118
          Does it make any difference if you have a RHD car, should it be rear left, rear right etc ...Rear left being furthest from the master cyl ?
          • twoqu
            • Sep 2003
            • 3103
            Usually it is the line furtherest from the M/C first, then in decreasing order of line length. Unless the manufacturer specifies some fiendish procedure like some BMW with traction control!
            • dan_b
              • Sep 2003
              • 3670
              Correct, it's to do with distance from the master cylinder. There's no point bleeding the shortest one first only to then bleed the longer ones afterward as you'll end up pulling crunty old gack through in to the short run that you'd already bled.
              Do the longest runs first, and bleed a significantly larger amount of clean fluid through than you'd expect - in S2Central it says to allow 500ml per corner, which I'd say is right.
              • mcandmar
                • Apr 2004
                • 5118
                Thats what i tought, everthing said RR, RL but is was for US or German models they were written for so i wasnt sure, thanks.
                  Eh? The link i posted was for the U.K model from MikeS2's site, didnt you read it?
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Yep and it added to the confusion
                    20v.org says, (US Site)
                    1 Brake master cylinder, then proportioning valve
                    2 Right rear
                    3 Left rear
                    4 Right front
                    5 Left front
                    Bentley Manual same as above (US Publisher)
                    S2Central says, (UK Site)
                    1. Clutch (Master then Slave)
                    2. Master cylinder (if bleed screw fitted)
                    3. Rear Passenger Side
                    4. Rear Driver Side
                    5. Front Passenger Side
                    6. Front Driver Side
                    And the site you linked says (UK Site)
                    1 Right rear
                    2 Left rear
                    3 Right front
                    4 Left front
                    So i think its wrong to be honest...
                    • Mikes2
                      • 1704
                      quoted directly from the worskhop manual so not sure why you think it's incorrect.
                      The manual does not specify a difference for lhd and rhd.
                      Mike
                      http://www.s2-audi.co.uk
                      • s2avant
                        • 2426
                        According to my system it is as follows:
                        Bleeding sequence
                        1 - Brake master cylinder (if bleeder screw fitted)
                        2 - Rear right wheel brake cylinder/calliper
                        3 - Rear left wheel brake cylinder/calliper
                        4 - Front right brake calliper
                        5 - Front left brake calliper
                        Ben
                        • |Maku|
                          • Apr 2005
                          • 248
                          • Home: Estonia
                          Question about bleeding RS2 Brembo calipers. As we know they have two nipples per caliper (each side has one). Is it crucial to bleed both of them?
                          • bertman
                            • Apr 2007
                            • 1173
                            • Current: United Kingdom
                            Yes you must bleed both banks.I think its inner bank first,outer bank second.
                            Rob
                            Ragussa green avant RS2+ spec
                            Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
                            Audi coupe gt-slow as hell but loads of character-sold
