314x30mm disc's
  • kingos2
    • May 2005
    • 129
    • Home: England Current: Germany
    314x30mm disc's
    i have the rs2 little red brake set up with 314x30mm disc's just woundering how other people space the caliper away from the disc on the rs2 bracket's and if rs2 bolts bracket to hub are shorter tham s2 ones i have them on temp in a manner i would rather not say so this info would be helpfull
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    You need four N 100 880 03 @ <£1 each from your Stealer.
    As for disk clearance IIRC you need to file/bend the pad retainers or something. I'm not sure as I machined my own brackets for my 323mm disks.
    There's plenty of threads here detailing all this.
    SS
