PN for ABS sensor Copper Sleeve?? ABS sensor fitting issue!!
  • s2dude
    • Nov 2005
    • 1631
    ok guys.
    Ive been refurbing some of the car lately (most of it!) and as my ABS was bust due to the previous f**kwit owner cutting wires and also due to missing sensor(S) Ive refurbed the hubs and got 2 new , 2 used ABS sensors to refit...
    Problem being I only have ONE of the copper ABS sensor sleeves that makes the sensor a snug fit into the hub.....
    Ive ordered 2 different parts from Audi (and the main parts dude ordered the latest bits) but they are totally wrong and nothing like the copper sleeves I need!!!!!!!!! (they are both plastic "cap" things of no use to man nor beast...)
    I cannot see these sleeves anywhere on the etka diagram and now we have tried the two parts I and the audi parts guy thought they might have been..................so now Im stuck!
    Can anyone help please?? I need to buy three of them ASAP!!
    Without them the sensors are a very loose fit in the hole (steady wab!)....I was thinking I could resort to insulating tape but Im not sure if this would screw the operating environment for the sensor magnetics???
    Any ideas or a Part Number would be magical!!!
    THANKS
  • s2dude
    • Nov 2005
    • 1631
    anyone??
    • s2dude
      • Nov 2005
      • 1631
      NOT looking good then?
      • Audi Parts Guru
        • 1317
        UK retail price from a friendly Audi stealer is £9.52 inc vat each
        • s2dude
          • Nov 2005
          • 1631
          Originally posted by Audi Parts Guru
          443 927 817
          You are my hero mate
          Many Thanks!!
          £9.52...Ouch!!!! "clamping sleeve" it says? sounds good to me
          • 90quattrocoupe
            • Nov 2003
            • 771
            Just a suggestion. Coat the abs hub hole with antiseize before installing. Otherwise the inside of the hole will rust, and expand inward squeezing the copper tube and abs sensor. Then next time you won't have to drive it out with a brass punch like I had to. Does a number on the sensor.
            Just another one of those things to do when do the brakes, everytime you bleed or change pads.
            Greg W.
