You know the bracket thats on the front suspension leg,
attached is pipes etc for brakes, what is it held on with & is this important part, & if it ever come off what would the damage be ? (when driving the car tho)
The brake pipes will wear away on the suspension leg and your brakes will fail. Eventually.
There is a small bolt on the front of the leg which holds the bracket in place and these are somtimes corroded and get broken off.
Re-drill and tap or replace the bolt as necessary to hold the brake pipes off the back of the suspension upright.
Mick said thanks for that, thats confirmed it ?
He has managed this but unfortunatly is now minus 5 "super strong" titanium
drill bits & a long piece of skin from the finger caught under the chuck key?
