I've been offered a pair of rs2 front callipers for a very reasonable figure (the princely sum of no pounds and no pence).
What do I need to fit them on my avant?
I assume the mythical 314x30 disc is suitable but will I need to have them milled down?
Will the rs2 caliiper brackets be suitable, or will I need custom ones?
will I need wheel spacers for the discs?
I don't want to get into the changing hubs if I can help it.
Ideally I'd like to complete the conversion using off the shelf VAG parts throughout, firstly because it's easier to replace anything that goes wrong and secondly because I get genuine bits cheap.
Any thoughts or suggestions would be gratefully recieved.
Ben
Ben
) I will have special brackets fabricated so one can use the full 314mm disc and no spacers (they are only shims dude, it's not what I call a hassle) at all.
:nana:
