b3 two piece rear uprights. pad question..
  • booested4door
    • Feb 2015
    • 120
    I have
    Audi B5 A4 rear hub (I had original s2 hubs, but for this setup i need that extra 8mm that the a4 hub has)
    Audi urS4/6 rear calipers
    Audi B5 S4 rear caliper brackets
    Audi B5 S4 rear vented brake disk.
    what pads do i use? I have b5 s4 pads, but they are too thick. the caliper wont slide over them. Do i need some urs4/6 rear pads?
  • GazzaG60
    • 4133
    hi, i came acrose a similar issue with the s2 upgrade. the calipers i had were basically the same as 80 ones and not the larger s4 items. seems the urs4 can use either the bigger 44's or the usual 80 ones.
    looks liek you got sold the wrong ones too..
