Rear Big brake help on CQ
  • konradwax
    • Mar 2008
    • 69
    I have s2 rear hubs. Upgrading to larger rear brake and ran into an issue. So here is what I have.
    Rear D2 s8 brake carrier
    Rear B5 s4 brake caliper
    Rear 8E0-615-310 brake discs
    I'm guessing I ordered the wrong rotor due to the fact that the hat spacing is too deep. So my question is what rotors do I need?
  • Colesy
    • Feb 2009
    • 2980
    A8 discs turned down by 20mm is what you need. Full details are on S2 central
    Sent from my Pixel using Tapatalk
    • konradwax
      • Mar 2008
      • 69
      8E0615301P Zimmermann Coat Z Disc Brake Rotor; Rear ; Vented 280x22mm
      Item# 8E0615301P
      this is what I have
      • konradwax
        • Mar 2008
        • 69
        ok, I see what I did. I need to get 300x22 rotor and machine it down to 280 because it has the right hat spacing.
        • PRY4SNO
          • 767
          Or you can swap rear hubs to b5a4q rear hubs to bolt up b5s4 rear rotors and save current & future machining costs.
          2013 Touareg TDI /// #farmenwagen
