Hello, new to the forum and new-ish owner of a CQ, and loving it
I have a 91 Coupe quattro B3
The ABS light has been on since i got the car few months back, The #76 relay under the dash does not have the circuit breaker connected, hitting the ABS light on the center console ABS light stays on, but i hear a click coming from under the dash.
now if i plug a circuit breaker to the #76 relay the ABS light wont come on after i turn the key, BUT the ABS pump starts to work, and wont stop unless i turn the key off or hit the ABS button on the center console.
while the pump is running the abs light stays off until i press the brake pedal several times, while stationary, and then stays on
any ideas how to diagnose/test/fix this, or have had similar experiences ?
thanks for your time
