Experienced a slight snag yesterday by cross threading the brake union nut into one of the monoblocks
This was done by hand threading the union nut in to the thread by about 3 turns and then using a spanner. Live and learn I suppose. I also looked at the thread in the other calliper and it's not too hot either.
I'm trying to find out the diameter and pitch of the thread in the callipers so that I can try and sort out the thread by running a tap down the original thread.
An M10x1.0mm nut (from a track rod end ball joint!) screws on to the union easily so I think it's M10x1.0mm.
I don' think that the thread is tapered?
Please let me know (if you do) as I quite obviously don't want to phook up my Monoblocks any further! All help VERY much appreciated!
This was done by hand threading the union nut in to the thread by about 3 turns and then using a spanner. Live and learn I suppose. I also looked at the thread in the other calliper and it's not too hot either.I'm trying to find out the diameter and pitch of the thread in the callipers so that I can try and sort out the thread by running a tap down the original thread.
