My brakes failed. Lucky for me I was in a safe area and managed to come to a stop.
I purchased a front set of calipers and rebuilt them myself. Easy job.
The only thing I never did was replace the cross over pipe, I never saw it to be required. BIG MISTAKE
It appears that the pipe rusted inside the rubber and eventually it burst when I applied the brakes.
Lesson when overhauling a used parts check everything.
All that glitters is not gold.
My fault should have done a better overhaul job.
After I open the brake circuit for any reason, I always do a test at standstill with assistance (vacuum or hydraulic) using full braking force. Good to check for leaks also
