Soft brakes
  • Chrissywissy
    • Jul 2019
    • 2
    Soft brakes
    Hi
    I am new to this site and owning an Audi I purchased a 1995 Audi 80 2.6 cabriolet automatic with various faults it seems as soon as I repair one thing something else goes wrong I have fixed the faulty window and roof. But now I’m having other issues first off the engine would speed up on idle causing the car to reverse into a wall as I was idling it in reverse and it shot back into a wall then the brakes went soft and finally yesterday it would not come out of park. I have tried to purchase the diagnostics leads but can only get the square ends not the curved corner ones I require. Can anyone help with any of these issues please it’s a lovely car to drive but I am unable to move it because of gearbox problems.
    Thanks
    Chris
  • Lago Blue
    • Jul 2009
    • 845
    Hi Sir,
    - No idea about the Xmsn stuck in park except would guess the easy things would be: check brake pedal switch and brake lights and fuse function and trunk hinge wiring (typical) and maybe even the (electrical portion of) the ignition switch (typical);
    - Find vacuum schematic for V6 with auto Xmsn (under-hood sticker?); and use vac schematics to do both visual and physical leak checks;
    - It may be that the idle and brake faults are related via vacuum. Eg: If air-con came on and engine sped up, engine rocked slightly, vacuum leak opened on brake booster to large vac hose seal (typical) which may magnify both idle and brake faults;
    - Is your car not still OBD 1 like this:
    - Auto Xmsn may also have it's own (separate from engine) fault codes?
    Also, consider that while "repair one thing (&) something else goes wrong" may seem unfair, that the alternative, everything breaking at once; might be worse.
    • Chrissywissy
      • Jul 2019
      • 2
      Hi
      thanks for that I will try what you have suggested . Do you know anywhere I can get the diagnostic leads. I have tried to purchase these online and also via eBay but they always send the square ended where mine Are rounded on the top corners.
      Thanks
      Chris
      • LHD_Kid
        • May 2006
        • 3697
        The 2x2 connectors are square one ended and have one or more corners cut off on the other
        • Lago Blue
          • Jul 2009
          • 845
          Chris,
          Re original factory DTC cable (a singular assembly, dual conductor): No, other than the dealer or at the wreckers (often found still in the glove box or the factory tool roll). You do know that as you are just pulling blink codes, even a cable is not actually required, a re-bent paper clip will suffice, see 2nd para (begins with: "If the engine runs,...") at above 12v.org link. What you do need to do is to ensure you have a serviceable Check Engine Light (CEL a.k.a. MIL) in your instrument cluster.
          "Some Audi's have no "check engine light" bulb installed in the dashboard assembly even though the circuitry is there."
          http://www.sjmautotechnik.com/troubl...g/100ecuf.html
          Separately re "yesterday it would not come out of park", it may be that the Xmsn yet needs to know you have your foot on the brake, hence previous suggestions re check tail-light function, trunk-hinge wiring etc.
