Rear Brake caliper will not wind back in???
  • Fat Audi 80
    • 10547
    Short story, I am replacing VERY worn out rear discs and pads on my coupe. (I am embarrassed about how low the discs and pad were - have I potentially caused the pistons to dislocate out of their grooves due to a very large piston excursion?)
    Anyway, I had real trouble winding the drivers side piston back in using a homemade tool consisting of locked up long nose pliers. Eventually the thread seemed to catch and it wound in.
    Passenger side, just will not wind back in. The piston rotates but does not wind in. Do I need more force (correct tool ordered) or is something else wrong?
    I notice on the tool I have ordered, the threaded parts locks inside the caliper body to exert force AND turn at the same time. I know I am not able to apply enough consistent force with the long nose pliers, is this all that is wrong or something else?
    (Calipers were brand new 10 years ago! )
    i have not done this for years, (if ever) so don't know the drill.
    Any thoughts appreciated.
    Thanks,
    Steve
    The Perfectionist
    • Dec 2017
    • 6017
    There is probably corrosion around the opening. Don't force it as the piston might not be going in true. If you can remove the caliper and do it on the bench, it's much easier. You will need to clean up the bore and piston and use a new seal kit. Then it will slide in easily. Use silicon grease on the seals
    • Fat Audi 80
      • 10547
      Cheers Dave, as I try and wind it in by hand I can see it is running in the bore slightly eccentrically. Does this sound like corrosion. I can't picture the pitch of the thread so don't know what to expect when winding it in...
      The Perfectionist
        • Dec 2017
        • 6017
        There is a seal in the bore opening. This may be damaged or twisted. If the piston isn't going on straight, it won't go in far. If you have a proper pipe clamp, clamp the hose and remove the caliper. Then you can pop the piston on the bench and have a proper look. You use an air line to remove the piston normally but is sounds like it's almost out anyway.
        • Fat Audi 80
          • 10547
          I have just seen a rebuild video on YouTube and can see what is going on now. I have a pipe clamp and I will pull it off if needs be and inspect on the bench...
          The Perfectionist
            • Dec 2017
            • 6017
            Good plan.
            this video is quite good.
            • Fat Audi 80
              • 10547
              Good plan.
              https://m.youtube.com/watch?v=YHPX8lEHFKs
              That IS the one I watched!
              The Perfectionist
                • Dec 2017
                • 6017
                Shame he didn't paint it after all that work!
                • Fat Audi 80
                  • 10547
                  Agree, it would have taken 15 mins to whack some paint on that!
                  The Perfectionist
                  • Fat Audi 80
                    • 10547
                    Update: I have stripped both calipers off the car to repaint them properly. Whilst doing maso Inaged to wind the piston off the offending caliper and discovered the inner seal was twisted which I think was preventing the piston going back in.
                    Anyway, calipers are both repainted black and new yellow stuff pads and new discs have been installed. Both sides are bled and all working again.
                    Thanks for all the advice.
                    The Perfectionist
