Discs for 323mm A8 set-up?
  • Ross
    • Aug 2005
    • 3399
    Hi,
    Well I thought the discs look liked they had some life in them. Then I checked out the inside edge
    Soo question, if I buy these from GSF will they be genuine? Found these 2 parts, which would it be?
    60297 BRAKE DISC-VENT 323mm BRE A8 98> 42.50
    62398L BRAKE DISC-VENTED 323mm A8 98> 42.50
    Or should I just vagparts these? Just like the idea I can get them from the same source as my pads, but don't want cheap knock-off's...
    Ross
  • s2driveruk
    • 12696
    top ones are Brembo which I think might be OE anyway in this instance, have them on mine and have been fine, weems to be wearing well and come with the zinc'd (I think) centres so they don't corrode. Oh and when you cut through the storage layer of wax they smell goooooogeous!
    1992 3b S2 Coupe
    • Ross
      • Aug 2005
      • 3399
      Cheers I'll get 'em ordered then
      Are local garages loathed to fit customer-supplied parts (like they all are with supplied tyres) or have you found any 'friendly' ones in Basingrad David??
      • s2driveruk
        • 12696
        no did mine myself, failry easy job providing you can get bolts off etc
        1992 3b S2 Coupe
        • Crawford_S2
          • 1555
          Top advice, i run the Brembos too, they are awesome and as mentioned come coated in zinc type primer so no rust on the hats so far!
          Ragusa Coupe gone!
