MK20 ABS coding - PLEASE HELP!
  • twenty valve
    • Oct 2010
    • 630
    Hi all,
    I know this isn't S2 related, but I wanted to post it somewhere it'll be seen... I'm struggling to fix this since I've read everything I can find online and not had any success asking on audi-sport.net
    Anyway it's concering my new daily - 2000 A3 1.8t quattro 180. The ABS currently doesn't work and VAGCOM won't connect to the control module (I bought the car with this fault and it came supplied with another used ABS unit). So I've plugged the new ABS unit into the car to test/code it (not yet swapped the brake lines over), and I've tried the following coding sequence
    1. Accessing the ABS controller menu in VAGCOM,
    2. Select "login - 11" then enter (suggested) code 40168
    3. Select "Coding -07" and enter new soft code
    4. Select "Do It!"
    5. Check if new code has been accepted in the "Controller Info" main menu
    6. Clear codes and rescan
    I've tried every soft code I can find online (from this list https://scantooldirect.wordpress.com...oding-success/). Some of these soft codes are accepted (i.e. once entered, the code in the ABS controller menu system changes) while other codes don't seem to be accepted at all. Regardless, none of the codes which are accepted have cured the problem; when you rescan with the new soft code, the same ABS fault code is returned (01044 - Control Module Incorrectly Coded 35-00 --).
    Any help would be massively appreciated.
  • twenty valve
    • Oct 2010
    • 630
    latest log file
    Friday,26,March,2021,13:38:54:00006
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 18.2.0.3
    Data version: 20180212 DS287.0
    VCDS,VAG-COM,VAGCOM,Diagnose,Diagnostics,DTC,Fault Codes,Data Logging,VW Scan Tool,Audi Scan Tool, VAG Scan Tool,Micro-CAN,HEX-USB+CAN,HEX+CAN,HEX-NET,VAG 11,VAG 12,VAG 14,VAG 15
    Chassis Type: 8L - Audi A3/S3 (1997 > 2005)
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine Labels: 06A-906-032-AJQ.clb
    Part No: 06A 906 032 R
    Component: 1.8L R4/5VT 0004
    Coding: 05600
    Shop #: WSC 06435
    VCID: 2D51BFB6E711382C83-515A
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 P
    Component: ABS 20 IE CAN 0001
    Coding: 03304
    Shop #: WSC 00028
    VCID: 3E7388FA3A77B3B42A-4B18
    1 Fault Found:
    35-00 - -
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 M
    Component: A3 KLIMAVOLLAUTOMAT_D77
    Coding: 03141
    Shop #: WSC 06435
    VCID: 326BACCAFE2F67D4DE-2592
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 3008
    Coding: 01104
    Shop #: WSC 06435
    VCID: 4581E7165FA1E06C6B-5178
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 C
    Component: AB-KOMBIINSTR. VDO D11
    Coding: 05444
    Shop #: WSC 00000
    VCID: 3365A9CE01356EDCD5-515A
    Component: AUZ7Z0Y1469308
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1469308
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F4D557E9DBDDABC01-4B18
    1 Fault Found:
    01316 - ABS Control Module
    49-00 - No Communications
    Address 35: Centr. Locks Labels:. 8D0-862-257.lbl
    Part No: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 15178
    Shop #: WSC 06435
    VCID: 428BFC0A4E8FD7544E-4EE6
    1 Fault Found:
    01134 - Alarm Horn (H12)
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: 60CF1682E043A54478-4B64
    1 Fault Found:
    01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
    27-00 - Implausible Signal
    End-------------------------(Elapsed Time: 03:51)--------------------------
