Avant Handbrake Cable Removal
  • Alistair E
    • 479
    As part of the refurb of the rear end of the avant I'm removing the rear suspension and subframe. A lot of things are now detached or loose but I can't see how the remove the handbrake cable from the guides through the wishbones. Should they just slide through the guides? At the moment they don't budge at all but can't see anything holding them.
    Thanks in advance
    Alistair
  • Alistair E
    • 479
    Bump. Anyone?
      • Dec 2017
      • 6017
      From memory there are some metal clips held on with 10mm plastic nuts. I will have a hunt through my pics to check.
        • Dec 2017
        • 6017
        Yes, there are two clips, one on each side. Remove the heat shields and you will see them. If I remember correctly, the cable is quite tight through rear wishbone. There is a collar as it enters the wishbone which slots in the hole if I remember correctly.
        https://audi.7zap.com/en/rdw/audi+80.../7/711-711050/
        • Alistair E
          • 479
          Thanks Dave. I'll try and have a look tomorrow.
