So the red (!) started flashing while driving but everything seemed fine. I had a look the following morning and the PAS Fluid was high and the brake pedal was like a rock. With the engine running and foot on the pedal it pulsed. I fitted a 2nd hand Accumulator and flushed the fluid cleaning the reservoir & filters then refilled with Audi Green fluid. I followed the bleeding routine with the steering which works fine, but the pedal is still rock hard.
I removed the return line from the accumulator to the reservoir and no fluid came out with the engine running. I remove the line from the Pump to the Accumulator and ran the engine and the fluid just trickled out - I was expecting this to be quite a flow.
Is my PAS pump the fault here or is it something else?
