90q brake master
  • chris
    • Jan 2008
    • 365
    90q brake master
    im fitting a vac servo brake master to my 90q track car , fitting braided lines , i am using a 2 outlet master, which outlet serves the front and which the rear circuits ? both outlets are on the os of the master , any help appreciated
    thanks
  • K Simmonds
    • Dec 2007
    • 7637
    Are you using a B3 90 Master cylinder? If so I could have a look at my B3 80 as that should be the same.
    Unless anyone else happens to know?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • chris
      • Jan 2008
      • 365
      i think it is a b3 one , no abs , so the lines are straight from the master to front and rear circuits, the master has only two outlet ports
      thanks
      • K Simmonds
        • Dec 2007
        • 7637
        Will have a look in morning for you...
        Also, I have the two small rear trims you need in good condition. Drop me a PM.
        1994 MTM RS2.
        2000 B5 TQS.
        • K Simmonds
          • Dec 2007
          • 7637
          Just had a look, my master cylinder has two outputs right at the front, one each side.
          Have you got a pic of yours?
          1994 MTM RS2.
          2000 B5 TQS.
          • sal_s2
            • 1291
            It doesnt matter as long as the rear circuit has the compensator or bias valve.
            • chris
              • Jan 2008
              • 365
              ah bias valve , great yes thanks
