Dual stage vacuum brake booster
  • Dual stage vacuum brake booster
    Hi guys. I bought another used dual stage vacuum brake booster. Is it posible to measure lsimply vacuum on these boosters with mityvac? It seems odd that on both boosters i can't measure any vacuum with my mityvac. Maybe thé mityvac isnt so strong to pull vacuum really fast and measure anything...i am little bit confused. I have two used dual stage boosters..each from different car.
    Odesláno z mého ASUS_X00QD pomocí Tapatalk
    Audi Coupe Quattro 2.3 20V
    Forget to mention that one way valves are working correctly with no leaks
      I found the leak. Its around Bolt holes. After I seal them with tape Its much better And holds vacuum much better. Should be there any seal?
        Actually is around one thread around hole. I Will use some Loctite to Seal IT And should be good. After i used a tape it holds vacuum nicely and still be there after 5mins
