Hi, I noticed my brakes holding on a bit if I drive for > 20 miles or so. No problem on short runs. Initially the thinking was seals had gone on the calipers - but these have now been replaced. Thoughts now turning to servo or abs. Anyone got any recommendations as to what to look at first?
Brakes ‘holding on’ after a longish drive
Have you got original brakes? Did you replace the slide pins when you did the seals?Nothelle S2 Avant
Urs6 plus project gone -
Have you done a servo brake upgrade?
I did one for a friend a while back. Car drove fine with me on a small test drive. When it arrived with him after a short drive all the brakes locked on. The rod to servo needed adjustment.Nothelle S2 Avant
Urs6 plus project goneComment
I’ve not touched the brake system for years (maybe 15 years) other than pads and disks. These problems surfaced after last disk change. We thought it might be the seals, but the problem persisted. Any advice on how I could check the rod/servo adjustment other than try and see?Comment
I think it's unlikely to be the rod length if you haven't touched it. Are all the brakes binding? Take the car for a gentle drive and try not to brake at all. After a few minutes, stop and feel each disc for heat (carefully).Nothelle S2 Avant
A bit more that might help with diagnosis: I put the car on the local ramp, before driving all four wheels freely spinning. After pumping brakes all still fine - short drive no problem. Long drive, both fronts significant bind (but even - no pulling left or right).
I’ll try the short drive and heat test. If they are warm - what is this indicating?Comment
It just indicates a binding brake. It will be very hot.
As it's both front brakes, were the new discs too thick?
Or maybe the new pads were too thick?
As the discs warm up they will expand slightly.
Did you replace the calipers pistons? Again, might be slightly too long and as they heat up will expand.Nothelle S2 Avant
With the new brakes on and the pistons pushed back there is still a bit of clearance between the brakes, if they were too big I'd suspect it too bind all the time.
After a drive, if you crack off the brake line to the caliper immediately they stop binding. So it appears it's holding pressure in the line after a drive. Any thoughts?Comment
