Not sure if this should be here or in the steering section but here goes:
I've been chasing an issue in my s6 for a bit now and i am running out of clear causes. The car drives great, tracks well, no issues, untill i hit the brakes. When i do, the steering wheel shakes quite badly. Only thru the wheel, ZERO vibration in the pedal.
Looking for causes. What i have done so far is check for loose bits in suspension (iDID find the jam nut on one tie rod loose, tightening DID help). Rebalance and rotate tires, inspect all 4 corners for anything obvious.
The issue persists.
I am on diy coilovers with blake dunham's camber plates up front and qa1 coilovers in the back. Brakes are brembo 17z on 323mm rotors up front, 310mm rotors out back with stock calipers. The fronts are drilled n slotted.
My next inspection will be to check the alignment. As mentioned above, i did find a loose jam nut on a tie rod so i now doubt9 the quality of the alignment that was done. I should add that it pulls to the right under brakes since i tightened the jam nut
But beyond that i am kinda stumped.... maybe fire the parts cannon and get quality plain rotors and pads for the front? But if it were brakes, i should feel something thru the pedal not the wheel?
Subframe bushings???
I'm going to replace the tie rod that was loose as i don't relish the idea of it having bounced around on the threads for god knows how long...
The issue persists.
