anyone have the brydon engineering drawings?
  • ottawa coupe
    • 861
    i've noted an issue with the adpater brackets i have on my s6 for 17z calipers. they are b5 ones from apikol. looks like they stuck the caliper out too far, caused the pad to ride the edge, and that is likely the source of my vibration under braking. Byrdon eningeering made brackets for my setup but stopped maufacturing them a while back. apparently he released his drawings to the world for anyone to machine. however, i can't find them. he also made brackets for 17z/323mm rotor combo for b3. i'd be looking for both. anyone have them saved anywhere?
    thanks
    1993 UrS4...aka the rocket powered living room
  • dr.strangelove
    • Mar 2010
    • 39
    I have a drawing for a big brake bracket. Not sure if it's the same one you're looking for. Unfortunately, im not able to upload attachments. Ill try a different format..
    • dr.strangelove
      • Mar 2010
      • 39
      Bbb
      • ottawa coupe
        • 861
        Brydon sent me drawings himself in the end. I'll post them up here if desired. I'll probably edit them a bit. He's released to the public but the drawings say proprietary sooooo....
