Hello I recently came across a set of used Cayenne brakes, I have been searching high and low to find suitable adapters. I see that EPYTEC sells cayenne adapters but states compatibility is for HP2 spec'd cars.
Does this mean it will not fit cars equipped with Girlings? Would I have to find HP2 struts to make these work?
Brydon engineering sent me the drawings for their 17z adapters for use with 323mm rotors. He's not making them anymore and says the drawings are public domain now so if you pm me your email, i can send the drawing to you and you can take it to a machine shop.
You CAN use apikol's b5 adapters but i have discovered the caliper is spaced a few mm too far out and i beleive was the cause of my brake vibration as things wore a bit.
