Audi RS2/Porsche 993 "Big Red" Brake caliper template
  • T Bo
    • Feb 2021
    • 16
    • Country: Australia
    Hi all,
    I have been searching for a brake caliper template for the Audi RS2/Porsche 993 "Big Red" Brake caliper (part no's. 993.351.425 / 993.351.426), with no success ! Any ideas where I could get one ? I want to check whether these calipers would fit in my wheels. (new 17 inch alloys to be installed on the car)
    • Dec 2017
    • 5992
    I can take some measurements on the car for you if that helps?
    • T Bo
      • Feb 2021
      • 16
      That would be really helpful thanks.
        • Dec 2017
        • 5992
        No problem. I will report later. My car has 17" standard Porsche Rs2 wheels. I will also measure the internal diameter of those.
        • T Bo
          • Feb 2021
          • 16
          Great, thanks again Dave.
            • Dec 2017
            • 5992
            About 74mm from outer edge of caliper to centre of hub bolt.
            • T Bo
              • Feb 2021
              • 16
              Great work. Could I also trouble you for the approx "thickness" of the caliper (distance from the rotor face to the outer edge of the caliper (see blue line on the attached picture). No hurry on this !
              • T Bo
                • Feb 2021
                • 16
                Sorry, and perhaps the approx length as per the blue line in the attached photo. No more questions, I promise !
                • Colesy
                  • Feb 2009
                  • 2981
                  Those calipers with 323mm A8 discs fit under all 17" wheels I have ever tried. The 314mm A8 discs with the correct brackets fit under OEM 16" wheels too.
                  So you should fine as long as you don't go for more than ~323mm discs. What wheels have you bought?
                    • Dec 2017
                    • 5992
                    Approx 295mm
                      • Dec 2017
                      • 5992
                      Approx 40mm
                      • T Bo
                        • Feb 2021
                        • 16
                        Great stuff Dave. Much appreciated.
                        • T Bo
                          • Feb 2021
                          • 16
                          I will be getting 323mm discs from A8. The wheels are made in Australia, which is where I live, by a company called Koya. Custom made to your specs. They should be OK as are big brake compatible. I just don't want to risk having to return items as international postage is significant. Thanks a lot for your advice, I'm confident now that all will fit. Tom.
